Tractor axles
44
01-15-2002 15:11:45
I have some ford tractor rear axles i do not know what they came out of this I do know they are for A 600 601 800 801 may be 2000 or 4000 four cylinder but which one how can I tell the difference
Are would they all be the same
Thank you
44
01-16-2002 16:49:01
 Re: Tractor axles in reply to 44, 01-15-2002 15:11:45
I guess the question should have been
are the 600 601 800 & 801 rear axle interchangeable are they the same right & left
Thank you
RICKWI
01-17-2002 16:22:47
 Re: Re: Tractor axles in reply to 44, 01-16-2002 16:49:01
Boy I think so, I've never seen any markings R & L and mine are all mixed together.
Scott
01-16-2002 09:46:33
600 and 800 models had course splines unless converted to fine, alot of these broke where the hub was fastened to the axle and 601 and 4000 models had fine splines.
RICKWI
01-15-2002 18:28:33
There are coarse and fine splined axles in that mix. I forget which were earlier, but I think it was the coarse.
