Casting Codes and Dates.....
awhtx
05-15-2008 19:24:52
Transmission: 312259 & H119
65380 (no model number) stamped on the left side.
2925 stamped on the right side.
Block: 310609 & 91 * 0
Rear end center section: 312478 & 91V
Lift cover NCA 501 B & 91D (except the D is backwards)
Right rear axle tube: No casting code & M318 (seen in the toolbox photo)
Left rear axle tube: No casting code or date code that I can find)
Radiator: NDA-8 (underlined) with an L under it & 1 59
It looks like I found an early 1959 Gold Demonstrator.
TONY JACOBS
05-16-2008 19:51:54
 Re: Casting Codes and Dates..... in reply to awhtx, 05-15-2008 19:24:52
Hello Alan , See how 1959 has some of these early date code letters like the 100 series tractors , that is what I was talking about in the email I sent you . Thanks Tony Jacobs
john_bud
05-15-2008 20:28:00
Some people fall in a field and come up smelling like a rose! (Where as I fall in a bed of rose peddles and come out covered in cow pies!)
Looks like a new resto project!
jb
awhtx
05-15-2008 20:48:47
 Definitely a restoration project.... in reply to john_bud, 05-15-2008 20:28:00
I forgot to mention that it obviously went through the factory transmission recall/swap. Trans housing is dated Aug 11, 1959 and the rest is dated late 1958 or early 1959. It looks like the dealership that did the trans swap followed the rules and restamped the tractors original serial number (65380) in the original location. Do I recall reading on this forum that the number stamped on the right side (2925) is a Work Order number or something similar?
TONY JACOBS
05-16-2008 19:48:36
 Re: Definitely a restoration project.... in reply to awhtx, 05-15-2008 20:48:47
Hello Again Alan , The number on the right side is the serial number stamped by the factory to track the transmissions after they left the factory and then back to the dealer then to the customer incase it was serviced or warrantied by a non-selling dealer . Thanks Tony Jacobs
