951 power adjust wheels
Al Bach
05-17-2008 13:36:07
How do you adjust the power adjust wheels?
Dean
05-17-2008 16:00:01
 Re: 951 power adjust wheels in reply to Al Bach, 05-17-2008 13:36:07
Al:
Remove the 4 clamps and bolts.
Lock the brake on the opposite wheel.
Slowly operate the tractor in low or reverse gear to move the loosened rim in or out.
Replace the 4 clamps and bolts once the rim is positioned as desired.
Tighten the clamp bolts very tightly. Tightening opposite clamps in several stages is recommended.
Repeat for the opposite wheel.
Note: I find it easier to jack up the tractor and manually rotate the rim about the disc after removing the clamps and bolts.
Dean
Dan(nyc)
05-17-2008 13:42:28
Al, here is a link from the archives thatmay help
