Order Ford 3000 Parts Online
3000 hydraulic chatter and jerky lift ...
JAE-Tx
01-17-2002 13:58:18
Early 3000 gas - has a lift problem. 3 point works OK, but chatters and jerks slightly while lifting.
What do I look for, and what is the proper way to bleed the pump? The IT manual doesn't go into any detail.
Thanks for the help.
rem
01-17-2002 17:10:41
 Re: 3000 hydraulic chatter and jerky lift ... in reply to JAE-Tx, 01-17-2002 13:58:18
Hi,
Does it do it when warm?
Mine does what you describe when it is very cold and the behavior goes away after oil is warm.
