1959 FORD 641 Workmaster
Chuck
01-19-2002 05:28:49
Had a bad regulator, I replaced it, hooked up the 3 wires as they were on the old regulator. Started the engine, it charged fine. When I shut it down, the amp meter went all the way to the left (-30). I started it again and let it run a while, showed charging while running and headlights indicated it was charging also.
I shut it down and 20 minutes later, the amp meter was at "0" and the battrey was dead.
Any clue as to where to start looking for the problem?
Thanks,
Chuck
Scott
01-19-2002 11:26:10
 Re: 1959 FORD 641 Workmaster in reply to Chuck, 01-19-2002 05:28:49
The points are melted together on the new one causing the discharge and drain. To check the wiring the large diameter wire goes to the armature terminal on the rear end of the generator, the battery wire goes to the junction block terminal, the field goes to the insulated terminal of the generator case, grounding is from the regulator mounting bolt to the uninsulated terminal of the generator case.
