12- volt conversion
44
01-22-2002 19:23:36
I am going to a 12-volt system This is for a working tractor 541 Ford I do not want to stay with 6 volt I have the GM alt. on the tractor At this time Just need to finish hooking up the wires I know that I can use a side marker light ButI want to Diode system I know where it goes in the system but what size or what do I ask for
does it Thank you
end is hot
DonP
01-23-2002 14:50:31
 Re: 12- volt conversion in reply to 44, 01-22-2002 19:23:36
I used the 12-volt wiring diagram from N-series.com, and one of the resistors in the pack from Radio Shack p/n 271-132.
Les Russell
01-23-2002 14:16:51
I switched my system to 12volts about 2 years ago. I have developed a short and the tractor no longers starts. It only get fire to certain points. I need a diagram of the 12 volt setup system to follow.I do not have the original papers. If you have such an item I would be interested in getting a copy. The place I purchased my 12volt kit is not in Chapter11.
44
01-23-2002 15:32:59
 Re: Re: 12- volt conversion in reply to Les Russell, 01-23-2002 14:16:51
What kind of altnator did you get in the kit that will tell the story
If your tractor will not start disconect
hot wire that goes to the altnator
get A hot battery
If all else OK should start
by the way A altnator will not charge a dead battery It will only keep a hot one chared
you can call me 337 457 7212
Have a good day
Larry
Pirate
01-23-2002 23:17:06
 Re: Re: Re: 12- volt conversion in reply to 44, 01-23-2002 15:32:59
You two ought to work well together
Don MS
01-23-2002 08:49:10
Go to Radio Shack and get a 1N4000 and install it with the marking Band toward the alternator.
