Model serial #
Baffled
01-24-2002 13:07:27
Don't know what Ford I have. Need help to ID.
Trans. is a Select-O-Speed. On left side/trans. hsg./horz. flat numbers stamped = top number 41205 under it is <>18495<>(with diamonds). What is Model, type engine, etc., etc. Was repainted at some point. Hood is simuliar to 2000/4000. Has Hyd 3-point, Aux Hyd control, PTO, 4 cyl. eng., Hyd pump has solid one pc out/return line. Your help is appreciated.
Scott
01-24-2002 18:03:40
 Re: Model serial # in reply to Baffled, 01-24-2002 13:07:27
You have a 1963 4000 series, the reason there are 5 digits to the model# stamped on the trans. is it tells how the tractor was built (trans.,pto,axle etc.). When you go to your New Holland dealer for parts tell him it has a 4 cylinder engine because Ford also made a 4000 with a 3 cylinder engine and they are totally different than yours.
