Order Ford 901 Parts Online
3 point on a 901
ken
04-10-1999 06:24:18
im having trouble getting my 3 point to drop or raise everytime i lift the loader the 3 point comes up i plumbed the loader off the live ports so i need help figuring this out is there something about the live hydrolics that would cause this?
ZANE
04-11-1999 04:14:24
 Re: 3 point on a 901 in reply to ken, 04-10-1999 06:24:18
You must have an auxallary remote control valve installed on the std. hydralics to use a loader.The only other way is to chain the lift arms down to prevent them coming up.This will limit the lifting power to the setting on the original lift control relief valve.
The lift pump is slow a pond water when used to lift a front end loader no matter which way you try to use it.The volume capicity is just not suffecient to raise the loader with any speed.
It's best to have a crankshaft driven pump for use with a front end loader etc.
ken
04-12-1999 12:58:01
 Re: Re: 3 point on a 901 in reply to ZANE, 04-11-1999 04:14:24
i did use seprate valves for my loader
all i did was tap into the live hydrolic ports to run the loader
