Order Ford 2000 Parts Online
Ford 2000 oil leak
Andrew Ingram
04-17-1999 18:13:07
Hi Folks,
I just inherited a 1965 Ford 2000 tractor. After my fist 30 minute spin I noticed oil leaking from what seems to be a pre drilled hole with a cauter(sp?) pin hanging from it. Is this meant to be or does this spell trouble ? Many thanks
Andrew
Al
04-17-1999 21:22:25
 Re: Ford 2000 oil leak in reply to Andrew Ingram, 04-17-1999 18:13:07
The pin is there to keep the hole from becoming blocked. You have a slight leak in either your engine or transmission seal. This is fairly common. Unless it is leaking a great deal, just keep your fluids topped off.
