Ford 1510 starting
Andy
05-14-1999 03:15:39
I have trouble starting this tractor. Glow plugs seem to be working fine.It takes several tries to start. Any ideas. Also how do I bleed the fuel injectors after replacing the fuel filter in fuel bowl.
Bern
05-14-1999 10:25:13
 Re: ford 1510 starting in reply to Andy, 05-14-1999 03:15:39
Are you SURE the glow plugs are working? Just because the indicator works doesn't mean the glow plugs do. Remove glow plugs, put power to them and make sure they get red hot on the tip. If they are OK, I would suspect a low compression problem. Run a compression check. To bleed, first bleed the pump, and the loosen the lines at the injectors and crank engine until fuel comes out of lines and the retighten.
