Order Ford 600 Parts Online
'61 600 Wiring Schematic
Windancer
05-21-1999 02:33:34
Is there a wiring schematic out there
on the net for a 1961 Ford 600? Does
anyone know what may cause the voltage
regulator to smoke?
Windancer
TROY
12-03-2003 14:09:21
 Re: '61 600 Wiring Schematic in reply to Windancer, 05-21-1999 02:33:34
Where do I find a wiring schematic for a 7500 series 3 cylinder gas front end loader/back hoe ford tractor built in 1975?
RKS
05-21-1999 04:05:15
You can go to the nearest New Holland dealer, and their parts department may have a wiring illustration on microfilm. Or, you can get a shop manual for the 600 series from the sponsor, YT, of this board. Not sure I ever heard of a smoking VR, but it could happen. That VR is probably a "mechanical" type and something may be shorting. However, the VR is mounted in a very tight place and the smoke could be from something else. If you or someone has tried to convert the tractor to 12V with an alternator, then they may have messed something up, or you could have some correctly connected wires shorting under the hood near the VR. You could easily go to an internally regulated 12V alternator, which you might already have, and just bypass the VR if you wanted to. You'd have to convert to neg grounding on the battery, and change any light bulbs, including the headlights, to 12V. Also, if you are positive you have a model 600, they were only made in 1955,6,and 7. I have a 56 that was converted to 12V alternator and neg ground. So, take the serial number with you when you go looking or ordering the shop manual. RKS
Dan
05-21-1999 14:08:44
 Re: Re: '61 600 Wiring Schematic in reply to RKS, 05-21-1999 04:05:15
third party image
or you can look at this one, which is quicker than driving to the NH dealer.
By the way, if it is a '61, you have a 601-series Workmaster, not a 600-series.
Dan
NAA60512
Don Temple
08-23-2005 13:13:56
 Re: Re: Re: '61 600 Wiring Schematic in reply to Dan, 05-21-1999 14:08:44
Dan
Thanks for the info:
I was looking for this exact info as someone had bastardized by 600, to my amazement you posted exactly what I as looking for.
Must be my lucky day...think I'll buy a lottery ticket
RKS
05-21-1999 15:39:44
.....Boy, DAN!! - you ought to put "sunglasses warnings" on that post, ha? Thanks, RKS
LARRY MCGUIRE
08-05-2001 19:54:39
 Re: Re: Re: Re: '61 600 Wiring Schematic in reply to RKS, 05-21-1999 15:39:44
DO YOU HAVE OR KNOW WHERE I CAN GET A SCHEMATIC FOR A1954 4 CYL. 601 ELECTRICAL DIAGRAM.. WOULD REALLY APPRECIATE ANY HELP , YOU CAN GIVE.. WILING TO PAY IF NECESSARY THANKS, LARRY
