12V Conversion Questions
David J (NM)
06-06-1999 07:05:39
A bad 6V generator is causing me to consider changing to 12 single wire alternator. I understand to chuck the regulator and conect directly to the battery positive post from the alternator. Then convert the positive ground by connecting the neg bat terminal to ground. Is there anything else I need to do to convert the positive ground... coil connections ? Why doesn't the starter care about the polarity change.
mark
06-08-1999 11:10:14
 Re: 12V Conversion Questions in reply to David J (NM), 06-06-1999 07:05:39
I bought a conversion kit through a ford parts supply house. Everything was included except the bulbs. It is the best thing I have done for the tractor. It will now start any time any where.
Jim Leff
06-06-1999 17:38:43
I always found it easier to have the gen. converted to 12 volts -change the coil voltage reg. and bulbs It works great.
