Order Ford 600 Parts Online
3600 in trouble!!
Shane
06-07-1999 19:00:09
Hi there.I need a little help with finding a service centre near my home for a ford 3600 tractor.The problem is that my father passed away about a year ago,and the tractor sat out for the winter.I have recently found the frost plug laying on the ground next to the tractor.When I reinstalled the plug and began to fill the radiator,water began to come out of the valve cover breather line.I then checked the oil and sure enough,mixed with water.I am assuming that this will be an expensive fix yet I would at least like an estimate on repair or replacement.If anyone knows of a service centre near Courtenay(located on Vancouver Island),British Columbia,Canada,please let me know.Thanks!
Bern
06-07-1999 20:32:03
 Re: 3600 in trouble!! in reply to Shane, 06-07-1999 19:00:09
Simple fix. You also blew out the soft plug(s) on the top of the cylinder head underneath the valve cover. Remove valve cover, replace plug(s), and you're on your way. Watch closely, however, for any leaks out the rear of the engine. There is also a soft plug behind the flywheel; not so easy of a fix! Let me know if you still want a dealership name, I could find it for you with a little asking.
