Order Ford 2000 Parts Online
FORD 2000 3 CYLINDER
BRAD
06-08-1999 18:10:30
I HAVE A HOLLY CARB AND HAVE TO RUN IT HALF CHOKE FOR THE TRACTOR TO RUN. I KNOW ITS GETTING LOTS OF GAS TO THE CARB. COULD THERE BE SOMETHING STUCK IN THE CARB? ANY IDEAS?
RICK
06-09-1999 19:09:14
 Re: FORD 2000 3 CYLINDER in reply to BRAD, 06-08-1999 18:10:30
Yes, you have some gunk plugging the main jet. Possibly a can of Mr. Carb Magic Cleaner might fix it, or open the needle a little, or take it apart and clean it.
Harry
06-09-1999 08:56:30
Sounds like a possible intake vacuum leak. Spray carb/choke cleaner around the intake manifold gasket area, while engine is idleing; If engine speeds up or stumbles, there's your leak. If nothing happens, gasket's OK. Be careful not to spray flammable aerosols onto a hot exhaust manifold; it could ignite..!!! As always, good luck!
john wilson
11-22-2003 18:23:46
 Re: Re: FORD 2000 3 CYLINDER in reply to Harry, 06-09-1999 08:56:30
i have o ford 2000 3 cyl, but my vacuum advance gave out on me. all of the dealers i have called said the do not make them anymore. does anyone have a suggestion?
