Fuel Tank
600Mutt
10-06-2004 14:12:16
I have a 1958 600. It has a 172 engine but is otherwise pretty much original. It also has a fuel gauge, so I think that means it isn't the original tank. I need a new sending unit for the fuel gauge. To get the right part I need to know what tank I have. Is there any way I can tell what tank I have by looking at it?
john in la
10-07-2004 06:48:45
 Re: Fuel Tank in reply to 600Mutt, 10-06-2004 14:12:16
First question I would ask is.....
Are you sure the tractor is a 1958 600. It may be that you inherited the serial number through a transmission change out.
Now back to the fuel tank. The tank might be from a 601/801. They used fuel gauges. The only way I would say to figure out which one you got is to measure its holding capacity. The 601 is 13 gals and the 801 is 17 gals.
600Mutt
10-08-2004 07:04:39
 Re: Fuel Tank in reply to john in la, 10-07-2004 06:48:45
Thanks for the help John. I was hoping not to drain & refill the tank.
I should have been more careful, my tractor is a 601. From what you say it sounds like the 601 could have come with a fuel gauge.
I'm pretty sure the rest of the tractor is original. From looking at my parts book and other tractors everything seems to be right. I honestly can't say if the transmission is original. The guy it came from was the second owner. He told me a little old farmer who only used the tractor to pull wagons story that I think is true. Places where you would expect wear or play are like new.
john in la
10-08-2004 07:44:57
 Re: Fuel Tank in reply to 600Mutt, 10-08-2004 07:04:39
Well if it is a 601 That makes it easy. All 601's I know of came with fuel gauges.
If the tank is orginal it is a 13 gal.
600Mutt
10-08-2004 20:18:10
 Re: Fuel Tank in reply to john in la, 10-08-2004 07:44:57
Thanks for your help and patience John.
