Order Ford 8N Parts Online
Ford 8n Battery problem
Blair from Onta
06-27-1999 19:52:47
Can someone tell me where my problem is? When I run my Ford 8n,the battery acid is leaking out of my battery down over the engine. When I stop and check the water level of the battery the caps of the battery seem like they are under pressure. One time the red cap of one of the cells flew right off. Is the problem over charging and if it is, is it the generator or the regulator or the battery. It is a 6 volt system.. Thankyou.
