Order Ford 6000 Parts Online
6000 PTO
Bob seND
06-30-1999 18:25:18
My 6000 pto turns when not engaged. I realize this is common, but when hooked to a 8" 60-ft.
auger, it turns it when empty. Is there some adjustment that can remedy this? It's a real nuisance.
Also the SOS doesn't lock into park most of the time. At times it will but most of the time I have to shut off the tractor to get off without the tractor creeping. Any suggestions?
Bern
07-02-1999 23:01:58
 Re: 6000 PTO in reply to Bob seND, 06-30-1999 18:25:18
Bob, the following is an excerpt from a previous post of mine regarding SOS PTO's: "Two important things about an SOS PTO that you need to keep in mind. (1)- there is no PTO brake on this tractor.The shaft will spin 99% of the time no matter what you do. (2)- the cable adjustment for the PTO is VERY critical.
To check for proper adjustment, with the control knob pulled all the way out, unscrew the fitting at the trans cover. While holding control handle all the way out with one hand, pull up on the conduit with the other. There should be a slight separation of approx 1/16 to 1/8 inch between the conduit and the flare fitting. Screw cable in or out as necessary to achieve this. Also check the total travel of the handle between full in and full out (after you have reconnected the fitting at the trans cover). This measurement should be approx 1 3/8". Be very certain of your findings here when you do this. Incorrect adjustment of the cable will likely lead to clutch pack slippage under load and consequently burn up the clutch, if this hasn't happened already. If the clutch pack is already partially damaged (i.e. warped plates), no amount of adjustment will stop it. If the clutch pack is not damaged, even a proper adjustment usually won't stop it, however any attached implement should. P.S. I'm not positive on the 1 3/8 measurement, but it should be very close. It should end up being slightly less than the total travel of the handle when the cable is not inserted into the shift cover."
These were comments I made to another guy with similar problems on his 800 tractor. These instructions were taken from a later model 2-5000 repair manual, but these transmissions are all very much similar in operation, and likely in adjustment. The instructions in the 6000 repair manual are vague at best.
As for the park problem, I'm thinking the first thing you should do is adjust the bands. Get yourself a hold of a repair manual for the proper procedures.
bruce
09-11-2000 17:30:04
 Re: Re: 6000 PTO in reply to Bern, 07-02-1999 23:01:58
i have a 3000 with sos that turns also. the local ford dealer gave me a real long song and dance about how expensive it would be to fix this very dangerous problem. they didn't have anything to say about the sos except to say when it breaks, junk the otherwise decent tractor. Does anyone work on these trans'?
