Order Ford 3000 Parts Online
3000 pto problem
hunter
07-02-1999 17:41:54
pto grinds when trying to engage. must kill engine put pto in gear and then start engine. help please
Gary H.
07-03-1999 17:47:38
 Re: 3000 pto problem in reply to hunter, 07-02-1999 17:41:54
If you don't have about 1 1/2 inches of free pedal you can adjust the rod to get it.After that if it doesn't work you are looking at splitting the tractor to fix. Either you'll need to replace as an assembly or replace parts.Depends on what you find will tell the tale. Your local Ford dealer should have the jig to adjust it up. Its not a thing you do without the proper tools. Good luck
Harry
07-03-1999 03:57:37
Sounds like a clutch adjustment is in order..... ...think more specific knowledge can be had from Guru Bern...
Harry
07-03-1999 03:57:08
Sounds like a clutch adjustment is in order..... ...tink more specific knowledge can be had from Guru Bern...
hunter
07-03-1999 10:37:56
 Re: Re: 3000 pto problem in reply to Harry, 07-03-1999 03:57:08
Harry, how can i get in touch with Guru Bern? also can you give advise on how to adjust clutch?
Harry
07-04-1999 04:34:28
 Re: Re: Re: 3000 pto problem in reply to hunter, 07-03-1999 10:37:56
A tractor is a tractor, etc. but different tractors have different idiosyncracies about them. I'll see if I can't find Bern on one of these postings, and get his E-mail address. In the meantime, ya just can't beat getting a shop manual ford the tractor you own. It tells and shows in detail every procedure you might have to do, and is well worth the money
hunter
07-04-1999 19:08:03
 Re: Re: Re: Re: 3000 pto problem in reply to Harry, 07-04-1999 04:34:28
thanks guys for the help. our ford dealer in town closed up business about 6mths. ago this tractor belongs to my pop and i've gotta do some adjustment on my jd as well.
