Fordson Tractors Discussion Forum
How do you tell what year a Fordson is?
Frank Richardso
08-28-2004 15:19:20
I"ve got an old Fordson I am trying to identify. How can I tell what year it is? Are there serial numbers to look for? If so where?
Steve in Canada
08-30-2004 06:07:25
 Re: How do you tell what year a Fordson is? in reply to Frank Richardson, 08-28-2004 15:19:20
The problem with Fordson serial numbers is so many engines were changed the year of the tractor may not match the year of engine which has the serial number on it.
Rob W
10-05-2004 19:25:17
 Kelowna BC Canada in reply to Steve in Canada, 08-30-2004 06:07:25
Steve I have a couple Fordson Questions for you .
Is there a serial # series like R-58749 in the fordson major diesel style ?
Weight ?
Horsepower ?
Thanx EH !
Rob
Jim Townsend
06-09-2005 23:45:21
 Re: Kelowna BC Canada in reply to Rob W, 10-05-2004 19:25:17
There is information on the Fordson pages as to how you identify your model. I have a 1960 Fordson Power Major and found the serial number on the right hand side of the motor below number one cylinder injector.
Butch Howe
08-28-2004 17:20:26
Fordson serial number is located on the right side of the block just below the head between the front two manifold studs. Should be a six digit number. Look closely, it may be painted over, rusted smooth or have a gasket over it. YT has a serial number listing under "research and info" on this site.
