Fordson Tractors Discussion Forum
Help 1959 Dexta gear box knock
Jim Bandy
09-15-2004 17:16:12
Dexta is running great. Took it for a ride tonight and gear box started knocking. Drained oil and it was milky. Should I fill it and see what happens or split the tractor? It only does it when the clutch is in. It is in time with the revs. High and low same noise, just slower. Thanks, Jim
Jim Bandy
09-16-2004 14:26:41
 Re: Help 1959 Dexta gear box knock in reply to Jim Bandy, 09-15-2004 17:16:12
No feed back, so I'm spliting the tractor. I've never done this so any input would be great. Thanks,Jim
Jim Bandy
09-17-2004 15:39:25
 Re: Help 1959 Dexta gear box knock in reply to Jim Bandy, 09-16-2004 14:26:41
Found the prodlem. Thanks for all the help. 200 year old oak fell on the house during Charlie. The Dexta should have the power to get her off.
capp
09-19-2004 17:55:39
 Re: Help 1959 Dexta gear box knock in reply to Jim Bandy, 09-17-2004 15:39:25
Jim, I was waiting for someone to answer your question as you were, what did you find when you went into her.
Capp
Jim Bandy
09-25-2004 06:30:08
 Re: Help 1959 Dexta gear box knock in reply to capp, 09-19-2004 17:55:39
Hello Capp, I found a washer had come apart and a peice got stuck in 2nd-5th gear. In my manual it was fig. FO547 #5 washer stuck in #6 Gear. Tapped the little peice out with a screwdriver. Got a new washer from a bearing shop and put her back together. She runs and pulls great. I'm very happy with this tractor. Jim
