Fordson Tractors Discussion Forum
Dexta Engine problem
Jerry Coles, En
09-30-2004 12:36:04
Hi I have a Dexta which has white smoke from the exhaust and thin runny black oil coming out from the exhaust/manifold joint. It was a poor starter with little power pickup when revved. The injectors were injecting poorly and I've had them serviced but I havn't started it since. Any Ideas??
Peter, U.K.
10-01-2004 00:31:51
 Re: Dexta Engine problem in reply to Jerry Coles, England, 09-30-2004 12:36:04
Jerry,
All the symptoms you describe indicate a very worn engine, in need of a rebuild. The oil from the exhaust manifold is probably by-passing the piston rings due to wear. White smoke in the exhaust usually indicates water, so its possible the head gasket has gone.
Regards,
Peter.
