Fordson Tractors Discussion Forum
Major fuel tank with broken bolt
Julian H
11-07-2004 18:40:36
I have encountered my second case of a stuck bolt in the front bottom mounting hole in a Major fuel tank. As in the first, I have rung off the head but there is about a quarter inch of bolt protruding. Heat would probably work but the fitting that receives the bolt seems to be brazed or soldered as well as rivetted. Can that fitting be heated enough to help with bolt removal without leaking afterwards?
Don Young
11-07-2004 21:19:11
 Re: Major fuel tank with broken bolt in reply to Julian H, 11-07-2004 18:40:36
If it is brazed you would be very unlikely to melt the brass with propane. If it is solder it would be very simple to resolder it. I assume you are familiar with the hazards and precautions involved in heating fuel tanks and with the many techniques for removing broken bolts.
