Fordson Tractors Discussion Forum
Need Dexta pimer pump and atomizer
Jim Jovanovich
11-14-2004 20:46:18
I just bought a '58 Dexta and it is missing its primer pump, atomizer, and manifold heater. I was able to start it by heating the intake with a propane torch, removing the plug where the atomizer valve should go, shoot some WD-40 in, and ignite it with the torch.
It doesn't run that well, but I plan on sending the injectors in for a rebuild first and seeing how it runs then.
I found I can buy a new primer pump from a company in the UK, but it is quite spendy. I was wondering if anyone out there has a better solution.
mwo
11-15-2004 06:42:01
 Re: Need Dexta pimer pump and atomizer in reply to Jim Jovanovich, 11-14-2004 20:46:18
We plumbed in a an outboard motor gas primer from W-mart. Seemed to work fine.
Tractorfix
11-17-2004 14:07:30
 Re: Need Dexta pimer pump and atomizer in reply to mwo, 11-15-2004 06:42:01
Link
They can help
