Fordson Tractors Discussion Forum
ford majors engine problem
colton
11-19-2004 16:42:11
my father just bought a major, two of the cylenders are not firing.they are getting fuel tothe injectors but wont fire.also it seems like diesel is getting into the oil. help!
Long Don
11-19-2004 20:48:39
 Re: ford majors engine problem in reply to colton, 11-19-2004 16:42:11
I am not sure but it sounds like a low compression problem. Check the valve clearances. Be sure the compression release lever is not partially engaged. If you do not have access to a diesel compression gage you can try switching the injectors to check which injectors and which cylinders will work. Put fresh oil in the sump. Hope this helps.
Mark 1
11-20-2004 07:17:24
 Re: ford majors engine problem in reply to Long Don, 11-19-2004 20:48:39
It could be a loose or cracked injector??This is the only place were I would think fuel could get into the oil.If you are goining to swap injectors you will have to remove the valve cover anyway.Maybe you can spot the problem before you remove any injectors.Try running the tractor with the valve cover off.It is pretty messy so look out.It is also quite noisey as well so wear ear protection.
Hope this helps.
GUSIL
11-20-2004 19:30:08
 Re: ford majors engine problem in reply to Mark 1, 11-20-2004 07:17:24
With the engine running and the valve cover off check the injectors with a black light. If you have a leaking injector or fuel line the fuel will show up with a milky color. This is sometimes hard to see with a small leak.
