Fordson Tractors Discussion Forum
carb for1953 fordson major
tony weir
11-23-2004 14:08:02
Iam looking for a carb kit for a 1953 fordson major do not know serial no where is it located on unit it has a zenith carb i am new to ford so any help would be helpful
Miles
11-24-2004 17:45:42
 Re: carb for1953 fordson major in reply to tony weir , 11-23-2004 14:08:02
Where are you located? I have several of the gas majors and there isn't much to these carbs.
Just disassemble, soak in carb cleaner for a day or so..use compressed air to clean all the passages, check linkage pivots for wear, make some new gaskets, check the float for holes.... and put back together.
Good Luck
tony weir
11-25-2004 17:00:29
 Re: carb for1953 fordson major in reply to Miles, 11-24-2004 17:45:42
this carb is not like other zenith carbs i have seen it stands about 6 inches tall
Miles
11-26-2004 18:13:54
 Re: carb for1953 fordson major in reply to tony weir , 11-25-2004 17:00:29
That is not original. All carbs from the N's right through the end of the NEW majors are the same Zenith except for the lower cast half which attaches to the manifold. Does your carb vent thru a hole cut in the engine cover?
