Hydraulic Oil
Jack R
01-05-2000 05:06:03
I need to change my hydraulic oil in my FMD and clean the screen.Can someone tell me what type of oil I need to buy?
Thanks.
Jack
Don(CO)
01-05-2000 18:34:00
 Re: Hydraulic Oil in reply to Jack R, 01-05-2000 05:06:03
Jack, The rear differential and hydraulic oil being one in the same in the FMD presents a couple of scenarios. First, do you operate the tractor in very cold temperatures? If so, I would recommend a multi-purpose fluid such as CO-OP Super HTB or a cross referenced oil like that. If you are in warmer climates an 80 or 80-90 gear lube will be adequate. One key point for the FMD is to store it under cover... they are notorious for leaking water in the rear fill cap and in the differential dipstick opening.
