Fuel tank steering wheel problem
jack
06-01-1999 22:45:22
I'm having a heckava time trying to get my fuel tank off. The wheel won't budge and that's that! I'm afraid to break it off... Any suggestions?
Karl
06-09-1999 07:41:27
 Re: fuel tank steering wheel problem in reply to jack, 06-01-1999 22:45:22
My grandfather's Fordson Major Diesel had a tank that leaked right at the seam. Apparently this was a notorious problem with these tractors. Our solution was to never fill the tank more than half full. You don't have to take the steering wheel off for this. :)
jack
06-13-1999 22:51:24
 Re: Re: fuel tank steering wheel problem in reply to Karl, 06-09-1999 07:41:27
wish that was the problem. I have lots of rust in the reserve section and whenever I run low or hit a bump or go at an angle the garbage gets into the fule line clogs the filter and shuts her down! so, tanks gotta come off...
Dick H TX
06-02-1999 10:22:32
Jack are you pulling your tank off to make, a repair. My Fordson has tank problems. I wonder if this is a weak point in the tractor. I have noticed other people asking about replacement tanks. Keep posted, because I'm about to try to pull my tank also. I guess I'll try solder,or some J.B.Weld. maybe someone can help us out.
jack
06-02-1999 22:31:57
 Re: Re: fuel tank steering wheel problem in reply to Dick H TX , 06-02-1999 10:22:32
I have rust, twigs, feathers and small reptiles in my tank that keep plugging my fuel filters. I want to r+r so that I can boil it out, and coat the inside with some stuff I keep hearing about. Rinsing it with diesal and draining on the tractor just doesn't seem to cut it. ;) Thanks for you help. I understand JB will work but weld braze might be better for you.
Harry
06-03-1999 21:35:28
 Re: Re: Re: fuel tank steering wheel problem in reply to jack, 06-02-1999 22:31:57
Jack, If you get your fuel tank off, there's a place in Stockton - ABC Radiator (800) 391-7401 - that does vintage vehicle gas tank restoration. You might check 'em out. I had to use a wheel puller and liquid wrench to get the steering wheel off my Dexta and it took a couple of days of soaking. Good luck, Harry
Jack
06-03-1999 22:55:11
 Re: Re: Re: Re: fuel tank steering wheel problem in reply to Harry, 06-03-1999 21:35:28
I will give abc a call when I get the tank off. I probably can clean and coat the tank if I can ever get the darn Steering wheel off. I live in Herald CA. Not too far from Stockton... so, This is a good suggestiong.
