Fordson Tractors Discussion Forum
Super Major Diesel
D. Hilman
12-21-2004 13:39:08
Will a super major head work on a Fordson Major?
I just aquired a plain Fordson Major with a cracked head. The seller provided a super major head but he doesn't know if it will work. I don't either.
Mark 1
12-21-2004 17:58:30
 Re: Super Major Diesel in reply to D. Hilman, 12-21-2004 13:39:08
I have used a 1959 Power Major head on a 1958 Major without trouble.I used the rocker arms and push rods from the Power Major as it matches the later head (bigger springs).Head gasket is different and you can use a later gasket, but hopefully you have the later sleeves with this motor?Word has it you cannot get a Major gasket anymore but there is a guy, Copperhead(I think that was his business name??) that can make a copy of any head gasket, so he claims.I found a NOS for mine.Also the intake and exhaust manifolds are different.Hopefully you have the Super Major manifolds, rocker arms, and push rods??If not just ask here and maybe we can get them to you.
JFP
12-21-2004 19:36:32
 Re: Super Major Diesel in reply to Mark 1, 12-21-2004 17:58:30
I have a super major i just put all new sleaves and pistons in.from what i could see the old sleaves i took out were not all the same...some were flat on top edge and 2 had a ridge sticking up on inside top edge probably about 2thou .When i opened new set they were the same 2flat top and 2 with a ridge anyone know why.the kit i bought was lost in stock since 1972,kit was all new,never opened.
Majorman
12-22-2004 06:52:59
 Re: Super Major Diesel in reply to JFP, 12-21-2004 19:36:32
I do not know where you got your sleeve kit from but it was not assembled by Ford.
The flat top liners are pre Fordson Power Major and were changed to the spigoted top because of head gasket failures with the more powerful engines.
If you have a liner mixture it is possible that the head gasket is not being held down on the flat top liners and will fail. You can use flat topped liners or spigoted liners but not a mixture of the two.
The later head gasket is OK with all models.
