Fordson Tractors Discussion Forum
VALVE CLEARENCES
ADS502
02-08-2005 09:54:41
DOES ANYONE KNOW THE SEQUENCE FOR DOING POWER MAJOR TAPPETS OR IS IT RULE OF 9
THANKS ANDY
Majorman
02-09-2005 23:54:25
 Re: VALVE CLEARENCES in reply to ADS502, 02-08-2005 09:54:41
Andy,
Rule of 9 works perfectly.
Woolman
02-10-2005 17:46:01
 Re: VALVE CLEARENCES in reply to Majorman, 02-09-2005 23:54:25
For those of us in the dark, please tell us what the Rule of Nine is. Thank you.
Majorman
02-11-2005 05:29:40
 Re: VALVE CLEARENCES in reply to Woolman, 02-10-2005 17:46:01
Rule of 9 = Add the valve numbers to 9. eg Valve 1 and valve 8, valve 2 and valve 7 etc. When valve 1 is fully open set the clearance of valve 8. and visa-versa, 8 open, set 1. Repeat this through the settings.
Only works on certain styles of engine.
Woolman
02-11-2005 20:20:28
 Re: VALVE CLEARENCES in reply to Majorman, 02-11-2005 05:29:40
Thanks, Majorman. Now I'll add that to the Rule of 72 that I seem to remember from my financial courses. Just having fun. I appreciate knowing what the Rule of 9 is. It would seem to only apply to four cylinder engines, and then only to those with two valves per cylinder, right? The minute an engine had nine or more valves the rule would not work.
Majorman
02-12-2005 10:06:59
 Re: VALVE CLEARENCES in reply to Woolman, 02-11-2005 20:20:28
It works with six-cylinder too but then becomes Rule of 13!
It depends on the engine. It will not work on any three cylinder ones I have come across or some of the four cylinder ones. I was taught it by an old Case and Fordson mechanic.
