Fordson Tractors Discussion Forum
Fordson type-simms mimmic timing
Brian ( CO )
03-01-2005 17:17:55
I bought a 1978 wiggins forklift with a ford model#380DF-6005-e 60.22LI. diesel engine 6yl.
The simms pump was off it as it was shot. I purchased a rebuilt pump. I found on the pump where to time the moon and half moon on the gear. On the flywheel I found the timing hole with the marks. Starting at 0 they go up above 25.
I need to find someone that Knows what number to set the timing on the flywheel and install the pump.
Being a truck driver I stopped in Oxnard Calif at the Wiggins factory and found out where to locate all this but no one could find the correct timing.
Hope somebody can hepl!
