Fordson Tractors Discussion Forum
What Model is my Fordson?
In Australia
04-01-2005 18:44:55
Can any one help me. I have an old Fordson tractor and I can"t work out what model it is. It has Fordson Major written on the cast iron radiator. The beltdrive for chaff cutter is on the side of it. H23N is written on the gearbox bell housing. The motor is a 6 cyl Petters diesel. I need to order manuals and parts for it so I need to give it a model. Thanks
Aussie Frank
04-02-2005 00:48:43
 Re: What Model is my Fordson? in reply to In Australia, 04-01-2005 18:44:55
Hello,
The number that you quoted is a casting number and it gives the exact day that the housing was made. The H represents the month wich is June, 23 the day and N the year of 1949. This would make the tractor an E27N Fordson. The engine you mention is a Perkins P6 TA which is a factory option on the E27N Fordsons from 1949 onwards and was also fitted to earlier models as a conversion kit. The standard tractor was fitted with a 4 cylinder side valve Petrol Kero or Petrol engine. I hope this helps.
Regards, Frank.
Majorman
04-02-2005 00:43:16
Think you have got a Perkins powered E27N Major built from around 1945 to 1951
In Australia
04-03-2005 04:56:31
 Re: What Model is my Fordson? in reply to Majorman, 04-02-2005 00:43:16
Thanks for the prompt replies and help. I"ll order the manual for it and start work on getting it going.
