Fordson Tractors Discussion Forum
looking for Fordson Major serial number
Ed in MN
05-15-2005 10:43:54
I have what is supposed to be a 1953 Major Diesel. I looked on the firewall for a serial number tag and found only the rivets or screws that probably once held it. Is there any other way to find a s/n or even the correct model year?
Majorman
05-15-2005 11:03:10
 Re: looking for Fordson Major serial number in reply to Ed in MN, 05-15-2005 10:43:54
If its 1953 it will be stamped on the flange behind the starter. Usually you need a good clean up to find it. The other place is under No.1 injector pipe but this then would be latter than 1953. Another way is to find all the casting codes on the main castings. Should be something like A1U which would be January 1st 1953.
