Fordson Tractors Discussion Forum
Fordson F air cleaner
Bigfinn
05-16-2005 05:55:04
It was posted a while back that a Saturn air cleaner could be used in a Fordson F. My question was if kerosene could still be run through the engine, or did that require the water vapor from the original air washer to prevent pre-ignition? Also, what is the part number for the air cleaner? Thanks!!
Aussie Frank
05-17-2005 19:02:35
 Re: Fordson F air cleaner in reply to Bigfinn, 05-16-2005 05:55:04
Hi,
You should be fine running kerosene with the saturn filter in place. Later models of the fordsons with the same motor used oil bath filters with no problems with pre-ignition. As for the part number of the filter you should be able to find the post by doing a search for saturn.
Regards, Frank.
Maine Fordson
05-17-2005 21:07:47
 Re: Fordson F air cleaner in reply to Aussie Frank, 05-17-2005 19:02:35
The Purolator A14650 filter fits right in the top of the air washer. You'll probably want to lay down a bead of silicone to get the best possible seal. (It's OK to cross-reference this part number to another manufacturer, they all seem to fit OK.)
Bigfinn
05-18-2005 04:38:57
 Re: Fordson F air cleaner in reply to Maine Fordson, 05-17-2005 21:07:47
Thanks!! I'm a long way from getting my 1927 F running but this will help.
