Fordson Tractors Discussion Forum
Fordson Major Steering Tyres
stompfrog
05-23-2005 13:57:31
Hi all. I've had a bad week, my 57 Fordson Major stopped steering and then I got a total flat on the rear left. I've bought the parts to replace the steering shaft (took the plate off the side and bits fell out!) but are there any tips to make the fix a bit easier? Also I want to change the flat tyre as well as replace the tube (v low tread) but have never done this on a tractor before (only a car). Do I need to buy BIG tyre levers, should I call in the pro's? Any advice on the 2 jobs would be great.
Thanks in advance
Scott
Aussie Frank
05-29-2005 22:31:36
 Re: Fordson Major Steering Tyres in reply to stompfrog, 05-23-2005 13:57:31
Hi stompfrog,
If your tyre and tube is dead and you are just throwing it away you can get it off by cutting the bead of the tyre with a sharp chisel. You can often even do this with the the wheel still on the tractor if you can jack it up high enough to get the new tyre under the rim. Realy only a good idea for badly spiked tyres that can't be used again but it can save some time and money. The new tyre usually goes on with not too much trouble with plenty of soap on the bead. Just take care with the tube.
Regards, Frank.
P.S. Just make sure you have a cold beer standing by for when you finish the job. Trust me you will need it.
StompFrog
05-30-2005 06:26:21
 Re: Fordson Major Steering Tyres in reply to Aussie Frank, 05-29-2005 22:31:36
Hi Frank
My Dad is an Aussie farmer he also said he has changed several while still on the tractor. I dunno though, I'm in England with very little in the way of tools but I like the idea of using a sharp chisel. I will throw that tyre away anyway. I have a good tyre on a rusted rim that I want to swap it with - do you think I could cut the rim away to make that one easier? The beer sounds like the best advice yet, no Coopers over here though, it'll have to be Fosters...
Aussie Frank
05-30-2005 18:15:10
 Re: Fordson Major Steering Tyres in reply to StompFrog, 05-30-2005 06:26:21
Hi StompFrog,
I would take the tyre off the rim while the rim is still on the tractor. Once the tyre is off use the rim of the tractor as a bead breaker for the rusted rim. The weight of the back end of the tractor should do the job fairly easily. Then I use lots of soap and the 5 foot crow bar that I use for digging post holes and another flat bar about 4 foot long. Same as any car tyre, just more swearing and more beer at the end. Breaking the bead is the hardest part. Once you have that done the rest will be OK, just heavy work. Clean and paint the rim while the tyre is off, use lots of soap on the tyre and rim and all will pump up fine. I don't like using grease on tyres as it attacks the rubber.
Regards, Frank.
P.S. Don't try cutting the rim. It will only cause grief.
StompFrog
06-01-2005 03:47:35
 Re: Fordson Major Steering Tyres in reply to Aussie Frank, 05-30-2005 18:15:10
Thanks Frank, I was wondering how to break the bead, Dad said the landy probably wouldn't be heavy enough. What about breaking the bead on the tyre that is still on the tractor if I don't want to cut it? I may be able to salvage the tube or do you think I'm better off replacing it anyway? I don't know if they are expensive or not...
Aussie Frank
06-02-2005 00:45:22
 Re: Fordson Major Steering Tyres in reply to StompFrog, 06-01-2005 03:47:35
Hi StompFrog,
I would get a price for the tube from your local tyre place and then make up your mind from there. My usual preference is to change the tube because once they get old and start leaking they usually develop holes all over the place and there is nothing worse than having to pull the whole thing off again a week later. Breaking the bead on your tyre just needs a ton or so of concentrated weight near the rim on the tyre. If you can get your draw bar high enough to fit the tyre under it just jack the back end of your tractor up and lower that down on the tyre. You need to take the wheel off to do that though.
Regards, Frank.
StompFrog
06-08-2005 12:13:18
 Re: Fordson Major Steering Tyres in reply to Aussie Frank, 06-02-2005 00:45:22
Hi Frank
Yep, I reckon you are right, I don't want to have to do this twice if I can help it. New tube, clean & paint the rim, use the rim still on the tractor to break the bead of the other tyre. Good bush mechanics tips - thanks for all your help!
mark 1
05-25-2005 21:25:25
For the tyre, I would take it to the pros. Mine was filled with liquid calcium and that made a mess before I could drive to solid ground in order raise the tractor and remove it. I tried to remove the bead with a 6 foot pry bar and had no luck. I ended up loading it onto a flatbed truck and taking it to town. It cost extra if they come out to fix it.
I have one steering box going back together and it is not easy. Try packing the bearings in wheel bearing grease to hold them in place. I also use a small magnet on a rod to fish out the ones that drop out. It took some time though and patience.
Maybe someone else like Majorman has a better way. Hope this is of some help and good luck, Mark.
stompfrog
05-27-2005 08:31:16
 Re: Fordson Major Steering Tyres in reply to mark 1, 05-25-2005 21:25:25
Thanks Mark, the grease tip sounds good. I think I'll have a crack at getting that bead over the rim and if it plays tough then I'll get the pro's to do it. Did you break the bead before you tried levering it over? Someone told me they come off easy but can be tough to break and inflate. I figure I'll try driving the landrover over it a few times before I try levering.....
