Fordson Tractors Discussion Forum
Major serial #
Doug Smith
06-21-2005 17:12:54
I recently purchased a fordson major, gas, not running, that I need some help in identifying. I would like to buy some manuals,etc. for this tractor but want to know for sure what I have before I do. The number I located on the flange behind the starter is 1230975.The 0 could be a C or aG but I am sure the other numbers are correct.I have good spark to the distributor cap, but nothing to the plugs. I can't see any problem with the cap, but think it must be that or the rotor. Would also appreciate hearing of any posible canadian sources for these parts.
Majorman
06-21-2005 23:41:05
 Re: Major serial # in reply to Doug Smith, 06-21-2005 17:12:54
Your tractor was built in June 1952 just six months after production of the Major started. Sparki problem is possibly the rotor arm, I have just had the same problem. Can't help you with a supplier in Canada though you might try Bareco or Vapormatic
