Fordson Tractors Discussion Forum
head torque
Doug Smith
08-01-2005 19:41:07
I am about to put the head back on my 52 major(gas). Unfortunately, the manual I purchased does not cover this particular model. I would like to know what the head should be torqued to, as well as the valve specs.
Clarence E. Hounchens
08-13-2005 22:17:28
 Re: head torque in reply to Doug Smith, 08-01-2005 19:41:07
I would like to know about the headtorque on a 50 ferguson tractor to-20.
Miles
08-02-2005 20:52:41
From the original Fordson repair manual..for Petrol
Head Bolts marked "100" 85-90 lbs-ft
Head Bolts marked "Bees", Newall" or "Ribe" 75-80
Make sure you follow the tightening order and re-torque after hot.
Valve Clearance .015" on both intake and exhaust. The manual says "idling hot". Use the rule of 9 for this motor. Fully compress valve 1 and then set valve 8 (1+8=9) and then 2 and set 7, etc
Regards
