Fordson Tractors Discussion Forum
Fordson E1A Major Torque Specs
Peter Short (UK
08-14-2005 03:52:48
Hey all Im 17 have the same love for tractors as a lot of u guys do (currently owning 4 of my own) and im rebuilding the engine on my Fordson Major. Now I know I should go out and buy a workshop manual but I have no money what so ever!
But if one of you guys could tell me/email me the torque specs for every last nut and bolt on the engine I would be very greatful! Thanks in advance Pete
Peter Short (UK)
08-14-2005 11:07:45
 Re: Fordson E1A Major Torque Specs in reply to Peter Short (UK), 08-14-2005 03:52:48
Hey I forgot to add that it is a diesel motor!
Thanks again Pete
mark white uk.
08-30-2005 00:44:24
 Re: Fordson E1A Major Torque Specs in reply to Peter Short (UK), 08-14-2005 11:07:45
Hi Peter
These are from my maintenance manual, settings are in lb/ft.
Head bolts (marked 100) 85-90# .
Head bolts (marked bees,newall high tensile or ribe)75-80# .
( # Maintain at higher figure )
Main bearing cap bolts ( marked 100) 70-75.
Front mounting plate bolts 12-15.
Timing cover bolts 12-15.
Big end cap bolts 55-60.
Flywheel bolts 80-90.
Flywheel ring gear screws 12-15.
Clutch to flywheel bolts 12-15.
Injector hold down bolts 12-15.
Delivery valve holder (injection pump) 30.
Sump bolts 12-15
Engine oil filter 10.
Hope these are of use to you.
Mark uk.
