Fordson Tractors Discussion Forum
Liftcover stucked
Nosdrof
08-17-2005 00:09:10
Hello! I am a happy owner of a 62 Supermajor with frontloader, it has not been used for 14 years but still runs pretty god. And I am planning to do service to the rear lift wich is not moving at all. Anyone knows o god way to free the rear liftcover
from the rearaxelhousing. Its been sitting there for ages possibly and it feels like its glued. Should i use a thin wire maybe to cut through the sealing?
Any ideas? Chears fellow tractorians.
Majorman
08-17-2005 00:18:17
 Re: Liftcover stucked in reply to Nosdrof, 08-17-2005 00:09:10
Have you removed the two nuts, one either side, from underneath the lift arm shaft? They can easily be missed. Otherwise a lever between the top cover and the rear axle is the way forward, you would have difficulty getting all round with a wire as there are pipes, dowels and studs under there.
nosdrof
08-30-2005 03:48:21
 Re: Liftcover stucked in reply to Majorman, 08-17-2005 00:18:17
Actually i had forgotten the two nuts under the lift arm shaft, thank you for informing me. Nevertheless, to actually losen the cover i used heatgun, crc556, a little hydraulic lift and a crowbar not to mention a lot of patiance.
I changed all the o-rings and the ram piston seal and cleaned all the valves. By the way i used a little handdriven wire winch fastened in the cage frameroof to lift it out of the tractor. Now the lift is working like a charm, i can lift my volvo 245 and leave it hangin for a week.
Cheers
mark white uk.
08-18-2005 05:20:49
Hi,
Just removed my lift cover and had the same problem.
I used two small hydraulic jacks packed top and bottom ends with wood and slowly jacked between top of axles and lift arm shaft.
Worked a treat for me and no damage done.
Mark uk
