Fordson Tractors Discussion Forum
1961 FSM ?'s
Bob Sarrazine
08-20-2005 21:53:45
I have a 61 FSM, and the top right bolt(shear pin) that holds the PTO to the rearend is broken off inside the PTO housing. I've about gone crazy trying to find one. Majorman said finding parts outside of England would be tough, where then in Egland can I find one? I'v tried to get www.fordson.freeweb.ni(or nl.), but can't pull their site. Is that the correct spelling? Would parts for a Ford 5000, Dexta, or Major work? If anyone knows of a FSM being parted out, please respond, or e-mail me @ BSarrazine@webtv.net I would like to put a fully hydrolic bucket on, so any info. on that would be appreciated. Thanks in advance, Bob
Majorman
08-20-2005 22:55:20
 Re: 1961 FSM ?'s in reply to Bob Sarrazine, 08-20-2005 21:53:45
The bolt you are asking for is common to all the Major range from 1952 to 1964. On a normal PTO it should be just a standard bolt available from most hardware outlets. Have you got a "raised" PTO with a gear lever on the back? As far as I can see from the parts list it is still a standard bolt though.
