Fordson Tractors Discussion Forum
questionable ser#
Brian Chambers
08-23-2005 10:43:55
Was given a "64 Major" also I&T shop manual copyright 1967. The ser# on front right of block is s 295866. This one letter and 6 digits(very legible) has me confused when looking at the manual ser# desiginations.Iwould really like to find the true year model.Any help? thanks bc
Majorman
08-24-2005 00:07:41
 Re: questionable ser# in reply to Brian Chambers, 08-23-2005 10:43:55
The serial number is from an industrial engine and there are no records that will help date your tractor. However if you find the casting date codes on the block,axles and gearbox housings this will give you a pretty good idea of the date. These codes look like A31B or 3B21. Check a post on fordson.freeweb/nl title "Dating your Major"
