Fordson Tractors Discussion Forum
rear linkage
graham newlan
09-13-2005 00:00:18
I have a 57 fordson power major. the rear linkage is not working tractor has not been used for a few years,replaced oil.But still rear linkage wont lift. Was told it may be a blocked valve.If so were is it located & how to fix it.
Thanks
Graham!
Majorman
09-13-2005 00:02:07
 Re: rear linkage in reply to graham newlan, 09-13-2005 00:00:18
Just a stupid question. Have you got the PTO in gear?
graham newlan
09-13-2005 16:29:53
 Re: rear linkage in reply to Majorman, 09-13-2005 00:02:07
Hi only had tractor few weeks previous owner said tracor hasnt been started for over 2 years.
I had a 35 fergie.it didnt need pto in gear to raise linkage.Is the fordson different.No PTO is not engaged> also when starts belches black smoke,replaced all filters and oil.
Majorman
09-13-2005 23:21:49
 Re: rear linkage in reply to graham newlan, 09-13-2005 16:29:53
This is a proper tractor not a Fergie :0)!
PTO has to be engaged to drive hydraulic pump. Black smoke indicates overfueling. Have you cleaned the air filter. Change the oil in here and check the wire gauze for clogging.
