Fordson Tractors Discussion Forum
suggestion for water forming in rear oil of Fordso
Farmer Tim
09-13-2005 10:08:22
To reduce the oil contamination from the condensation settling into your oil in the rear end of your Fordson Majors, when you change the rear axle oil, drill a hole for a small fastener, and put a small screw with a gasket through the hole, from the inside, and a nut on the outside. Then, when you have not used the tractor for a while, reach under, and loosen the nut slightly, to drain the water out, until oil starts coming with. Once the water is out, then tighten the nut up again. This has worked all summer for me, and so far, no milky oil in the rear end.
