Fordson Tractors Discussion Forum
remote hydraulics install on Major?
Jason, NW Ontar
09-15-2005 07:30:11
I see the hydraulic outlet under the seat, and I'm wondering if anyone has had success installing a valve spool there for implements needing hydraulics. thanks.
Majorman
09-15-2005 09:50:44
 Re: remote hydraulics install on Major? in reply to Jason, NW Ontario, 09-15-2005 07:30:11
You can run a valve from here withou trouble. Only thing to watch is that when you blow the PR valve, you will have to drop the main control lever to regain pressure. If you have a PR Valve on your valve chest, set this lower than the tractor and this will eliminate the problem.
