Fordson Tractors Discussion Forum
Fordson Dexta leaking
wraiths
09-18-2005 16:44:40
Was out running the old girl the other day an noticed a thin stream of oil leaking out . Stopped an began looking an found a small hole about 1/8 inch a few inches behind the bellhousing. Once it cooled it did'nt leak hardly at all. Just wondering if anyone else has seen this an what I can do to fix it.
Majorman
09-19-2005 00:13:07
 Re: Fordson Dexta leaking in reply to wraiths, 09-18-2005 16:44:40
If it is clean oilits leaking from the gearbox through either the gaskets or one of the input shaft seals. If its black and dirty it will be from the rear main oil seal on the engine. Both jobs require splitting the tractor.
