Fordson Tractors Discussion Forum
TranyPTO oil
Bob Sarrazine
09-26-2005 18:09:15
I recently repaired the PTO on my FSM. Afterwerd, I filled the trany at the large plug near(forward and below) the clutch pedal, with the full level marked on the housing. The 3 piont hydrolics worked fine the first time I used them, but I let the tractor set a couple days, now the 3 point does'nt raise at all. I checked the fluid in the large fill hole, and was up to the full mark. Then I noticed a dip stick just to the left of the clutch pedal, checked, and it is completly dry. I thought the trany and PTO have a shared resivior. Any suggestions?
Majorman
09-26-2005 23:25:00
 Re: TranyPTO oil in reply to Bob Sarrazine, 09-26-2005 18:09:15
They are two seperate compartments. Put 40l of the same oil in through the filler plug behind the seat.
