Fordson Tractors Discussion Forum
rear end fluid change
matt in pa
09-29-2005 06:30:44
After searching the archives for a while, I am fairly certain that I should replace the rear end fluid in my 55 major to 30w motor oil. I know that it currently has hydraulic fluid in the rear, but it is due for a change. My question is how does motor oil react with remote cylinders? I bought an aux. hydro control valve, which mounts in front of the lift quadrant, and I want to put some lines on the tractor to run a hydraulic cylinder for a grading blade.
Also, I do not have my manual handy, so can someone tell me how many quarts of gallons of 30w I will need for the rear end and the engine?
Thanks.
Majorman
09-29-2005 10:07:38
 Re: rear end fluid change in reply to matt in pa, 09-29-2005 06:30:44
Ford's have been using 30W engine oil in the backend since around 1958 so if there was any problem with loaders etc. it would have shown up by now.
I run straight 30W or 10/30W in mine. Be aware that you may have severly damaged the final drive units dif. etc. and possibly the hydraulic pump if you have been running a hydraulic oil in there. These oils have very little lubrication qualities.
