Fordson Tractors Discussion Forum
carburator on fordson f
rjohn wi
09-30-2005 18:25:16
Awhile ago there was a discussion on a replacement carburator that would work on a fordson f in a pinch. I think someone suggested using a carb off a comet 6 cylinder. It is a low profile carb. I tried it and have to run it just about fully choked. What modifications should have to be made in order to make it work? Like drilling the high speed jet etc. Thanks in advance Roger
George Best
10-04-2005 13:31:28
 Re: carburator on fordson f in reply to rjohn wi, 09-30-2005 18:25:16
The first Fordson I had was modified to use a carb from a Model A Ford. The manifold was simply flipped so the updraft carb could be used and it had a vertical exhaust stack. Worked pretty well.
rjohn wi
10-08-2005 19:49:02
 Re: carburator on fordson f in reply to George Best, 10-04-2005 13:31:28
I think I like that idea because than it would have a hi speed adjustment on the carb Thanks
Roger
Butch Howe
09-30-2005 20:13:44
Hi Roger, I've used the same carb on a Fordson manifold and didn't have that problem. I don't believe any other modifications are necessary. You might clean and put a kit in the carburetor. May be a jet plugged.
rjohn wi
10-01-2005 19:52:51
 Re: carburator on fordson f in reply to Butch Howe, 09-30-2005 20:13:44
Thanks Butch; I took the carb apart and blew it all out. Put it back together and it did run better. Now I have to explain to my wife why It makes such a mess when I drive it around the driveway. No, really she is a farm girl and understands. Rubber tires would be nice. Roger
