Fordson Tractors Discussion Forum
fordson diesel running on one cyclinder
hahter
11-02-2005 17:44:01
I have a major diesel that is only running on the number 3 cyclinder. The injector pump has the vacumn governor on it. I only get fuel to come out of the number 3 injector pump line. I took all lines off the pump and still only get fuel from the third fuel line, so I can eleminate plugged injector lines. Any help would be appreciated. Thanks Terry
Majorman
11-03-2005 07:08:11
 Re: fordson diesel running on one cyclinder in reply to hahter, 11-02-2005 17:44:01
If you have bled the fuel system and have no air in it and the fuel flows freely to the lift pump below the fuel filter and through the filter itself down to the pump when you operate the lever, then you may have stuck plungers in the pump itself.
This is a specialist job and costly. Take the pump to a diesel shop. You need a clean room like an operating theatre and lots of special equipment.
