Fordson Tractors Discussion Forum
Model F patent date
F me
11-10-2005 15:31:06
Greetings,does anyone know the last year the patent date was put on the model F dash?
F you
11-13-2005 12:08:32
 Re: Model F patent date in reply to F me, 11-10-2005 15:31:06
If I had to take an educated guess off the top of my head, I'd say 1923. Wouldn't bet the farm on it, though -- and, as always, your mileage may vary.
F you, too
11-13-2005 12:30:16
 Re: Model F patent date in reply to F you, 11-13-2005 12:08:32
Actually, let me clarify that. I'm pretty sure the patent dates (eight or ten of them in all) were cast into the dash for as long as the Model F was manufactured, but there was never a date later than 1923. Earliest date to appear on the dash (at the top of the list) was 1912, I believe.
Also, on the earlier F's the dash's production date was cast into the back of the dash (facing the air washer). They used to let the dashes cure for a few weeeks or a couple of months before using them, so the casting date does not correlate with the date the tractor was assembled.
Hope this helps to answer your question.
F me
11-15-2005 13:10:56
 Re: Model F patent date in reply to F you, too, 11-13-2005 12:30:16
Thanks, I was thinking,like you said that 1923 might be the last date put on the dash.I think I will give up trying to date my tractor.Too many parts from different years to zero in on the date.
Maine Fordson
11-17-2005 00:18:03
 Re: Model F manufacture date? in reply to F me, 11-15-2005 13:10:56
Have you cross-checked the serial number on the engine? That's the first thing you should do. That will tell you when the engine block was produced. (Apparently, there was a guy on the Fordson production line with a stamping set [like a bunch of small cold chisels, except they have numbers 0-9 instead of a blade], and he hand-stamped the engine serial number into the block of every tractor that went by him on the assembly line. You'll usually notice that the serial numbers are not in a straight, even line.) If you don't know where to look for the serial number, it's just above the fourth bolt that holds the manifold on (nearest the radiator), and it's often obscured with grease, paint, rust or a combination of the three. Use a small scraper or screwdriver blade and a toothbrush-sized wire brush. Once you have the number, compare it to the serial matrix (you can find it on several sites on-line, or write me & I'll look it up for you).
As for your statement "Too many parts from different years to zero in on the date," you often find that there is a mish-mash of parts on Fordson Model F's. The basic mechanical design was unchanged for the ten years they were in production here in the U.S., and farmers are a thrifty bunch to begin with. Why spend good money at the parts store when you can remove a needed part from another rusting hulk on the scrap pile behind your neighbor's barn?
You may be able to get a pretty good idea of the tractor's year, you just have to keep at it. (I think that there is a date cast into the underside of the rear axle, for example.) There are folks out there in InterNet-land who know a lot more about Fordsons than I do; keep asking questions until you're satisfied.
-- Maine Fordson
