Fordson Tractors Discussion Forum
super dexta transmission stuck
angelbay
11-11-2005 18:21:18
Hey out there, I haven't been here is a long time, advice in the past was good enough that my tractor has been well for a few years! Where is Burrhead? I have a '63 super dexta and today, in use, it got stuck in low 2nd. I can change Hi and lo, have neutral using hi/lo but the 1-3 and reverse is stuck in 2nd, no neutral, etc. I can move the shifter side to side but it will not move into 1,2,3 or R. By the speed I can tell it is in 2nd. What can I do? Any ideas? Thanks, Steve
angelbay
12-10-2005 02:27:35
 Re: super dexta transmission stuck in reply to angelbay, 11-11-2005 18:21:18
Thanks a bunch, removed the lever, welded ball up, replaced, works like a champ! Boy was I worried! Thanks again, but where is Burrhead?
Majorman
11-12-2005 08:54:25
Standard Dexta problem, the ball on the end of the gearstick is worn and has come out of the selectors. Undo the four bolts around the gear sticks, remove and re-arrange selectors, replace levers and bolts. It may happen again but it is an easy fix by building up the ball a little and reshaping it.
